Holley linkage and trans kickdown
Guest
Posts: n/a
I need a little help finding the right parts to work with my Holley street avenger carb and my 400/727 in a 73 D100. I have this type of linkage brakect to work with.
I figure I'm not the first with this setup and was looking for some part numbers.
Thanks
Thanks
Your throttle cable goes under a "u" bolt attaching to one end and the other end is the return springs. The two holes are where the carb studs mount the assembly. Fairly straight forward. The kickdown will need to go onto a stud you will have to make up to fit the holley lever.
Also note that Holley has the mopar adapter bracket that you can by from them that bolts to your carb {if yours is not the mopar type of holley}.
Another option for the kickdown would be the cable aftermarket type.
.........who makes them? help me, my mind is gone.........
I believe Lokar make a KD cable.
Guest
Posts: n/a
Thanks but I guess I should be a little more specifc. My trans kick down linkage will interfere with the mount for the throttle and cruise control. I rigged things up for now without the piece in the first post but I want to use it eventually.
I don't have the holley parts that ate meant for mopars so I'm thinking they may clear but I don't see how.
I'll look into the lokar parts, I think I remember seeing simetiing like that in one of my catalogs.
The Bandit
Jul 21, 2013 01:50 PM
