Holley linkage and trans kickdown
Old Jul 3, 2009 | 06:49 PM
Crazy4Carz.Com's Avatar
Your throttle cable goes under a "u" bolt attaching to one end and the other end is the return springs. The two holes are where the carb studs mount the assembly. Fairly straight forward. The kickdown will need to go onto a stud you will have to make up to fit the holley lever.
Old Jul 3, 2009 | 10:55 PM
theomahamoparguy's Avatar
Also note that Holley has the mopar adapter bracket that you can by from them that bolts to your carb {if yours is not the mopar type of holley}.
Another option for the kickdown would be the cable aftermarket type.
.........who makes them? help me, my mind is gone.........
Old Jul 3, 2009 | 10:59 PM
72RDRNR's Avatar
I believe Lokar make a KD cable.
Old Jul 3, 2009 | 11:14 PM
thanks, Im glad you jarred my nogin. could remember.[oldtimers again].
Old Jul 4, 2009 | 08:25 AM
yes, Lokar probably the best option.
The Bandit
Jul 21, 2013 01:50 PM
KJoeZ61
Sep 27, 2009 05:07 PM
nesparky
Jun 2, 2009 08:26 AM
DartConvertible
Mar 28, 2008 06:24 PM
button
Jan 26, 2008 05:30 PM
