how to adjust vacuum advance
Old 07-19-2008 | 11:58 AM
gotdust's Avatar
i want to add some timing to my 73 360 duster with electric choke if it matters, how do i set it with vacuum advance, and what do i need to do it that way or can i just plug off vacuum at dist and do it there? i want about 38*. thanks
Old 08-08-2008 | 07:59 AM
ef8340's Avatar
Senior Member
Originally Posted by Doc
You should be able to do that through the vac hose hookup with an allen wrench. I have never done it .. but will be doing it for the first time on an RV project I have.
is there a allen head screw inside of the hose port on the vac adv module?
Old 08-08-2008 | 05:20 PM
ef8340's Avatar
Senior Member
id like to do this on mine how would you set it is there a spec chart ??? thxs again
Old 08-10-2008 | 01:14 PM
ef8340's Avatar
Senior Member
well i messed around with it and the hesitation is out of it but i havent takin it up the road yet need to get some trans fluid 1st seems that it leaked out some from sittin
Dodgecrank
10-15-2013 11:23 AM
Hoff701
04-17-2013 01:19 PM
SPICOLIE203
12-29-2011 10:42 PM
nesparky
06-02-2009 09:26 AM
68camperspecial
04-02-2009 02:46 PM
Quick Reply: how to adjust vacuum advance
