How do I remove the steering coupler from the steering gear.
Old Apr 10, 2010 | 12:35 PM
cvon's Avatar
Junior Member
I'm new to this mopar forum and need assistance removing the steering coupler from the manual steering gear of a 69 roadrunner. I've managed to remove the steering column and wheel from the car but would like to disassemble the steering coupler from the manual steering gear. The lower pin is out and you can see clear to the other side through the hole. It still does not pull off. Does it screw off? How is it removed at this point? help?
Old Apr 10, 2010 | 03:44 PM
Welcome to the forum!!!! How about some photos ????? We would love to see your ride.....
Old Apr 11, 2010 | 04:49 PM
cvon's Avatar
Junior Member
Thanks I will give it a try. Is there a pulley that I can buy to pull the coupler off, if this does not work?
Old Apr 11, 2010 | 04:51 PM
cvon's Avatar
Junior Member
Sorry this car was a michigan survivor that was disassembled because of severe rust. I was taking apart the steering column components so that someone else could possibly benifit from its donor parts.
Old Apr 12, 2010 | 05:47 AM
cvon's Avatar
Junior Member
OHD,
The coupler moved 1/8 of an inch with the heat and then stopped. As I mentioned in the above thread there does not seem to be a pin in the hole at the bottom of the coupler. I can put a nail in the hole through to the other side. It's still not moving. Is the pin that holds it on the gear hollow or solid? I never removed a pin from this location, it has always been hollow.
Old Apr 12, 2010 | 09:49 AM
rdrunner1974's Avatar
coupler pin
Use a punch 3/16" diameter and drive the pin out. It is hollow, often called a roll or spring pin.
Paladex
May 18, 2014 05:40 PM
cuda341
Mar 6, 2014 03:12 PM
TRAMO
Jan 19, 2014 03:27 PM
Sean Griffin
Apr 4, 2013 08:25 PM
olibass1
Apr 22, 2011 07:10 AM
