how strong is a 8 1/4 rear end
Old Oct 30, 2008 | 05:43 PM
mahd's Avatar
what is the most hp that you can have will still using a 8 1/4 rear end. Are there performance parts for a 8 1/4 that can handle lets say 450 hp.
Old Oct 31, 2008 | 05:43 AM
What is the axle in?
I wouldn't put more than 300 to an 8.25 rear axle. You can get spools, lockers, posi units, upgraded axle shafts for them, but you would be better off to install a 9 in rear, 8.75 rear, 9.25 rear or a D60 rear axle
Old Oct 31, 2008 | 04:36 PM
correct. I had an 8.25 in the back of my 01 dakota and I pulled it out because the bearing were toaste after 62,000 miles. I swapped in a 9.25 out of a durango R/T and never worried about it.
Old Oct 31, 2008 | 04:46 PM
i have a stock Dana 60 in my car
what horsepower is it good up until?
Old Nov 1, 2008 | 02:40 AM
depends somewhat on the spline count. if its a 19 spline then I wouldn't put much more than 400 to it without upgading the axle shafts, carrier, R+P and bearings. If its got the 29 spline shafts (i think) then i wouldn't worry about it unlesss your building a strong motor.
I have seen a lot of weaker, small axles live under huge tires and/or lots of power. Then again, the people driving them were not beating on them. I've also seen guys tear apart the R+P Iin a D60 with a set of 35s and a stock V8 in a truck.
It all depends on how your going to be driving it. If you take it easy and just like to cruise (maybe hammer down once in a blue moon), then you shouldn't have a problem. If you like to take it to the strip every month or more, then spend the extra money in building an axle that is designed to take it.
Old Nov 1, 2008 | 07:50 AM
oh, ok, then it's fine for me.
chuck1934
Jun 13, 2013 10:33 PM
72_coronet
Jan 12, 2009 05:57 PM
killermopar
May 4, 2008 10:47 AM
thekinzuakid247
Apr 3, 2007 07:37 AM
thekinzuakid247
Mar 25, 2007 01:56 PM
