intakes ?
Old 11-07-2010 | 03:54 AM
67Polara's Avatar
intakes ?
was looking on ebay for random parts for my car and i came across a high rise intake manifold. does anyone know the pro's and cons of having one ?
and are 340 & 360 intake manifolds any different from a 318's ?
Old 11-07-2010 | 03:58 AM
They are designed for motors that run higher RPMs (usually 3500-10000).
They are not that great for street driving.
Old 11-07-2010 | 04:05 AM
67Polara's Avatar
oh, bummer, what about the intakes with two 4bb carbs ?
i'm looking at getting a blower scoop and i want it to stick out of the hood, is there any way to raise it with out a highrise intake ?
Old 11-07-2010 | 04:09 AM
Dual quads is very cool but usually you need a motor that is at least mildly built and the linkage will need some work or you'll have to look around for a kit. What size motor do you have?
You could get a 2" carb spacer (cheapest way) or raise the motor some (would take a some work). You could also add a blower to the motor and it'll lift it that way.
Old 11-07-2010 | 04:14 AM
67Polara's Avatar
have a 318, when i baught it i was told it has a cam bored and has race heads. but i have no idea if all of this is true tho.
by blower is that like the whole super charger deal or ?
Old 11-07-2010 | 05:01 AM
1966sportfury's Avatar
A.K.A Bob Dodge
a blower is kind of the same as a super charger. just crams more air than a super charger or turbo. turbo is another option?
there 2x4 intake made for the 1500~6000 rpm range
Old 11-07-2010 | 06:58 AM
Archer's Avatar
67 -
Could you define "hi-riser" ? What you (or the seller) is calling a hi-riser may not be what we're thinking is a hi-riser. There's always a gray area.
Archer.
Old 11-07-2010 | 07:30 AM
Barfly's Avatar
I have been looking at intakes on ebay for awhile now and I have seen intakes advertised as High Rise and they may very well be, but it seems they are simply another version of a Air Gap intake.
The main thing that's been holding me up is how much money I have to spend and were the intakes are coming from. What I've found is for a SB Mopar made in the USA will cost you $200 and up. The ones advertised as new for around $129 - $149 are made in China. Another thing is that Weiand intakes while priced around $189 and up are also made in China, however my understanding is that this was not always the case.
I don't mean to high jack the thread and turn it into "USA vs China" but I feel knowing where the intake is made is an important part of making the purchase. Personally I will feel pretty weird strapping on a China made intake to my Classic '72 Dodge 340.
That in mind, I have China made Sunpro gauges all over my dash......
Joe.
Old 11-07-2010 | 10:39 PM
67Polara's Avatar
Originally Posted by Archer
67 -
Archer.
on the intake where you put the carb, it sits higher then a normal intake would.
Old 11-07-2010 | 10:41 PM
67Polara's Avatar
Joe.
i agree, i wouldnt want an intake made in china on my car... i'm not sure where my after market guages are made, i'll have to look into that.
Old 11-07-2010 | 11:19 PM
Silverick's Avatar
If you need the riser or "lift" for your "blower scoop" a buddy of mine came up with an idea a while back to make a spacer for the scoop on his boat. The key part was that it had to look good and shine.
So, he and I drove to the Goodwill Thrift store, went to the pots and pans section and started looking for a polished stainless steel pot or pan that was a certain diameter for the spacer. I think that it took two stores to find what we were looking for.
Finally found it, bought it for about $3.00, took it home and cut the pan down to the needed dimension. It still had the rolled edge at the top and it looked bitchin'!
It shines, looks like a custom piece and you would never think that it once was a cooking pan!
Old 11-08-2010 | 12:34 PM
Aron's Avatar
I would love to see a pic of this!! And im not saying this cuz i think that it might look all white trashy like, im saying it cuz my grandfather does stuff like this and i think the final product is amazing sometimes.
Old 11-08-2010 | 05:31 PM
blue 68 gts's Avatar
I know a guy who has a blow "air cleaner". But he wants a pretty penny if hes going to sell
Old 11-08-2010 | 09:00 PM
Silverick's Avatar
I tried to upload a picture of my buddy's thrift store spacer but, the picture is too big.
Old 11-08-2010 | 10:00 PM
67Polara's Avatar
might just go for a hood scoop then =P
not looking to pay out the *** for somthing along those lines.
Old 11-19-2010 | 06:42 PM
polarman's Avatar
You're better off. If you don't know exactly what your cam profiles/bore/compression ratio are, then you don't want to swap to a different intake and/or carb. If all of those components aren't matched, it will never run right.
I forgot to mention exhaust manifolds as well. All of these things basically have to be able to move the same amount of gasses to function properly together.
Old 11-20-2010 | 05:55 AM
Email it to me and I'll resize it and post it.
Old 11-21-2010 | 02:29 AM
toad490's Avatar
Instead of hi-rise or not, the question should be single plane (strip) or dual plane (street). If you have a dual plane try adding a carb spacer and see if the engine likes it, if it does maybe a single plane will be the route to go. If you already have a single plane then changing that in it's self will make very little difference.
Polarman is right, you have to have a balanced package. All that changing parts randomly will do is cost you a bunch of money and be very frusterating. Find out exactly what you have now and then determine the weak points and upgrade them. I know this from bitter experince, I've thousands of dollars in useless and unused parts sitting in my shop.
Old 11-21-2010 | 05:57 AM
Barfly's Avatar
That's interesting, do you have a dual plane aluminum intake for a 340 sitting around?
Joe.
Old 11-21-2010 | 09:44 AM
toad490's Avatar
Joe.
Sorry no, but I do have one for a RB. All my stuff is for a big blocks, I just never could see the sense in small blocks. Just my opinion.
440-4x4
12-10-2009 10:43 AM
02-24-2009 08:03 AM
gregscram
09-12-2008 09:25 PM
Doc
06-16-2008 10:31 PM
maclaganbros
09-11-2007 09:11 AM
Quick Reply: intakes ?
