Issue with a small oil drip out of the PCV hose at the intake manifold port
Old Jun 21, 2010 | 09:49 AM
1923tbucket's Avatar
Is this a common thing to have a very slow annoying drip out of this hose? Its a 440 and being on my street rod the engine is fully open. So this oil drip takes oil and puts it all over my windshield. Its possible it could be the hose I guess but i've tightened the clamp now with a socket and we will see if it holds. However before it was dripping out of the pcv breather cap itself until i sealed it. Its a very annoying problem any help on solving it will be apprectiated, im tired of cleaning oil out of my intake manifold valleys.
Old Jun 21, 2010 | 10:01 AM
Polaradude's Avatar
Replace the defective pieces or get better clamps etc. What's it going to cost total, $30 bucks ? for a new hose etc. Just throwing that out there man.
Old Jun 21, 2010 | 10:19 AM
Yea I was just wondering if its normal to have an oil accumulation in there, if so cool i should be ok then.
Old Jun 21, 2010 | 10:57 AM
sweeperking's Avatar
If you sealed your breather there's no fresh air entering the crank case so manifold vacuum is drawing the oil through the pcv valve. The reason why it was dripping from the breather in the first place I dont know except maybe some excessive blowby or over full on oil.
Old Jun 21, 2010 | 11:55 AM
1966sportfury's Avatar
A.K.A Bob Dodge
it shouldnt come out at all, unlees the crancase is getting pressurised some how, not good, (blowby)
Old Jun 21, 2010 | 08:40 PM
It is a little full on oil, with whats dripped out it is still over the full line by a bit. Im thinking of changing it shortly anyways. She rarely gets driven but I need to get around to it. I tightened the clamp and im barely getting any out now. However the breather on the opposite side isnt sealed it's just the pcv cap that I sealed around the edges where it was dripping out. I'll try leaving oil out of it and see if that helps. The motor has about 12k on it and runs strong I sure hope theres not blow by.
Old Jun 21, 2010 | 11:33 PM
A.K.A Bob Dodge
is the pcv hook up to the carb?
Old Jun 22, 2010 | 09:14 AM
no I believe its on the spacer plate underneath the one carb, i see there is another port on the carb however too. Should I plug the spacer plate and hook it to the carb?
2darts
Oct 3, 2014 08:56 AM
98 SNAKE EATER
Mar 28, 2013 04:49 AM
1923tbucket
Apr 19, 2011 10:35 PM
M1 Manifold
May 21, 2009 02:23 PM
dzltd02
Oct 28, 2008 08:25 AM
