Just curious about 383's
Old Jul 26, 2010 | 12:23 PM
DandyD's Avatar
I Just picked up a very clean, prepped and painted 67 383 block bored .40 over. Plan to build a budget performer. If I were to use a factory forged 383 crank, can the motor still be stroked? What would be a good solid way to build withour braking the bank?
Any suggestions would be appreciated.
Old Jul 26, 2010 | 12:49 PM
Crazy4Carz.Com's Avatar
Stroked means changing the crank, rods, pistons. So, no, you cannot use the crank. Run it as is.
Old Jul 27, 2010 | 04:19 PM
what are your plans for the motor?
how much horsepower do you want to make?
Old Jul 28, 2010 | 06:22 PM
deadkelly's Avatar
alloy heads , good cam , inlet manifold , 750 carb , after market ignition & dizzy , higher compression pistons , 1 7/8" 4 into 1 headers , stall converter if auto , good air cleaner , good timing chain , lightweight fan . + all the other stuff you need like rings , bearings , gaskets , machining ect ect .
Old Jul 28, 2010 | 06:33 PM
1966sportfury's Avatar
A.K.A Bob Dodge
383 are good, 400s are a better performer (not factory form) with a 383 forged crank higher comp pistons, etc etc,,,
a good cam, edel rpm manifold is a good street choice manifold, port the heads what comp ratio are you running know do you know? or can find out?
whats breaking the bank? my bank may be a bit smaller than yours, how much can you sink into it?
Old Jul 30, 2010 | 11:50 AM
DandyD's Avatar
Thanks for the recent input. I now have a line on a factory forged crank, rods and cast pistons from a 383 HP motor from a 69 Road Runner. According to my research, I should be able to get a compression ratio of around 10-1 if I had factory heads. I am looking at probably going with 440 Source Stealth or possibly Edelbrock heads. Would this contribute to a further gain in compression and power? Sound realistic? Any further input would be appreciated.
DandyD
Old Jul 30, 2010 | 06:39 PM
scotts74birds's Avatar
Deadkelly is the resident 383 expert [If you can understand him!]! I dont know about your budget, but I would buy forged pistons, JMHO. A set of forged pistons matched to the "cc" volume of your heads will put you where you want to be, and end up with a great all-around combination!
labradorian70
Sep 24, 2014 09:44 AM
maxaud
Sep 23, 2010 07:34 PM
plymouth4406
Jun 27, 2008 08:52 PM
79mopower
Nov 13, 2006 08:08 PM
