KB pistons and a possible 360 build.
Old Jul 12, 2009 | 04:02 PM
the only reason i am against KB is because i have heard lots of horror stories about them breaking apart
Old Nov 6, 2010 | 08:15 PM
rfarmelo's Avatar
This is a pretty late reply but thought it would be worth documenting what I've heard... I just put together a 440 with KB and a few folks told me not to use them. From what I gather, some people have probably had trouble with them because they are not clearancing the top piston ring correctly. you need more clearance that "stock" due to the higher temps they see on the KB pistons. If they don't have enough clearance, they can close up, bind and tear the top of the piston apart.
I haven't had any issues with my new engine but it's only be been running for a few months and I don't run it very hard.
Rob in Roseville Ca.
'73 B'cuda 440/727
Old Nov 6, 2010 | 08:56 PM
Minnesota Guy's Avatar
Stickshifted,
For what you are building, the KB pistons are fine. You can run bolts, you dont need studs in your botom end. Overkill for your build. Mopars have awesome bottom end strength. For a midrange truck, I would use your J type heads..with unmilled heads and the 10:1 piston, you will be at 9:5...mill your heads .050 or so and get more compression.......definately port the heads or at least the bowels. I port everything I build.
I would ace the performer intake and give it to a 318 builder...That is junk (unless it is Performer RPM.)..They have 318 type ports....It will slow you down.(experience on a 340) The 340/360 thermoquad intake is by far superior and a great piece!! (if on a budget)Just put an adaptor on it and run the Carter...(I run this set up) the adaptor automatically gives you a taller manifold. Just grind out the center section (see my photos in mybucket showing an thermo intake) Use 323 or no higher than 355 gears if you need some mileage...
Dont go crazy on the cam for what you are doing....Too big and you kill bottom end...Go with a Comp Cams XE 268 or 276..(Mopar Muscle loves the 276 XE)..Will give you a little rump sounding and run power brakes,...Great torque...WIth the compression you are looking for you should easily get 13-15mpg.....Make sure with KB pistons--you file the rings per their instructions to their specs....
I built a 360 with the Summit kit..few years back Hyper Eu pistons--I think those were Federals advertised at 8:5--9.0....kit was 300.00 then.....But they were flat tops--no dish..I shaved my heads .060 and with a cam in your range....I had 150lbs compression per cylinder....It turned out to be 9.5 --It would run on 89 octane but 91-92 would have been ideal..........Those were good pistons--and no filing of rings.......Decent kit with some changes like moly rings..etc
the KBs are good--and they have diff compression ratios....
maca
Mar 27, 2015 07:12 PM
smackhonda
May 25, 2010 07:49 PM
smackhonda
May 20, 2010 08:08 PM
smackhonda
Dec 21, 2008 04:46 PM
jonny5
Feb 25, 2007 04:03 PM
