latest update and headache
Old Jan 18, 2011 | 06:03 PM
68 Fury Rookie's Avatar
360 is in the Fury and running very well. Problem I am having now is when running the lights flicker inside and also head lights do that. Car has new alternater and voltage regulator. Battery checks as ok. The more rpm the worse the gauge jumps around. Anyone have a good idea. I have a friend with a 360 upgrade and he did not have this. Thanx Frank
Old Jan 18, 2011 | 06:51 PM
62Furious's Avatar
Is this in the 68, and if so, did you go to electronic ignition, I changed to the solid state blue box voltage regulator and it boiled my battery so I went back to the old black box voltage regulator and have had now problem, see if that helps
Old Jan 18, 2011 | 06:52 PM
Silverick's Avatar
I have a totally bone stock and original '68 Fury III/383.
The charging system worked great then, a bearing went bad in the original alternator and I bought an alternator from Kragen Auto Supply.
My gauge is now doing the same thing as yours and didn't before the alternator change.
So, I am figuring that my alternator and voltage regulator are not matched or something. I went to the local speed shop asked about a voltage regulator for my Fury, they looked in the books and their question was: "Is it a 45amp or 60amp alternator?"
I told them that I didn't know.
So, I think that I either had a 45amp alternator, inadvertently put a 60amp alternator on the car or vice versa and the voltage regulator is not matched to whatever I have.
Like I said.... the charging system worked perfect before the alternator change. I saved the original alternator and am going to have it rebuilt to its original specifications in hopes that my theory is correct.
Old Jan 18, 2011 | 07:22 PM
i have a 60 amp alternator as that is what all parts stores are carrying. The old one was shot and is gone. I have an electronic voltage reg coming and hopefully that cures it. The first replacement alternator was also defective so this problem is frustrating us. Hope the new one cures it.
Old Jan 18, 2011 | 08:42 PM
Silverick's Avatar
There's a good shop in SF that rebuilds DC items and the reverse rotation starter on my boat also needs a rebuild.
So, I'll see if I can get them both up there and I'll let you know if this works.
Keep me posted if you figure this out! Thanks, Rick
Old Mar 18, 2011 | 06:26 PM
update today
latest pics. Pleased so far and no headaches at this point
Attached Thumbnails latest update and headache-wheels.jpg   latest update and headache-wheels2.jpg
Old Aug 18, 2013 | 02:57 AM
Mike Derwin's Avatar
Help Charging system
I have a 1969 Fury III I changed the voltage reg. and the alternator the battery is a week old. So my problem is that went I test the battery to see if its charging its not but when I take the positive battery terminal off it is charging but when the positive battery terminal is connected to the battery it is not charging
Old Aug 18, 2013 | 04:35 AM
mr340's Avatar
Please start a anew thread.
Colorado_Fury
Dec 31, 2013 09:53 AM
Crazy4Carz.Com
Jun 6, 2012 06:49 PM
68 gtx
Oct 16, 2009 04:42 PM
sam z
Apr 17, 2009 04:45 PM
Crazy4Carz.Com
Oct 8, 2008 08:21 AM
