Need higher gearing
Old 10-25-2010 | 09:29 AM
edrk213's Avatar
Need higher gearing
I have a Dana 60 with 4.10-1 gears, and i would like to know what would be the easiest way to get better highway driving gears? Thank you!
Old 10-25-2010 | 10:09 AM
You can swap out the ring and pinion for a set of 3.73 or 3.54 gears or swap to another Dana 60 axle that already has those gears in it. You can not go any lower than that though due to design unless you swapped out the entire axle for a Dana 61.
3.73 gears are somewhat common through Dodge, Ch*vy and F*rd trucks. 3.54 gears are mostly found in F*rd trucks.
Old 10-25-2010 | 03:32 PM
3.54 gears were standard on 4-speed hemi and 440 cars from 66-71 i believe
Old 10-26-2010 | 03:50 AM
Only thing I am unsure of is the pumkins the same on a car D60/9.75 and truck D60? I know that a low pinion dana 60 from any truck will fit into another low pinion dana 60.
Old 10-28-2010 | 07:00 PM
rr69half6bbl's Avatar
Your gonna have around 7 bills in a re-gear approach, gears, bearing and seal kit, then doing it. Is it a heavy puller, can you put a dana 44 in it out of a few years newer truck? Or Id get another dana 60 from a J yard, id say thats cheaper then doing a re-gear.
36knuckle
06-14-2011 05:41 AM
Dave E
10-13-2010 11:13 AM
Dave E
04-28-2010 08:18 AM
GEORGE68HEMIRR
04-07-2010 10:09 AM
