need transmission help!?
Old Aug 29, 2011 | 01:27 PM
mr.300's Avatar
1965 727, put a new pan on, changed the o rings on speedo cable as well as the shifter cable. put it all back togeather and now i dont have 3rd gear. was fine befr so not sure what it could be took it back apart today to make sure i didnt forget somthing and it all looks fine no metal etc what the hell could it be? thanks for the help in advance
Old Aug 29, 2011 | 02:02 PM
samuelcosmo76's Avatar
Did you adjust the shifter cable right? Maybe its really in "2".
Old Aug 29, 2011 | 02:11 PM
mr.300's Avatar
is it that sensitive? i put it all the way in and then slowly brought it out . but no change.
Old Aug 29, 2011 | 02:12 PM
mr.300's Avatar
what is the correct method for adjustment?
Old Aug 29, 2011 | 03:22 PM
mr.300's Avatar
its all back togeather now if i shift manually it will go into 3rd somtimes, or if i shift to n then back to drive it will catch 3rd every third try or so.
Old Aug 29, 2011 | 04:20 PM
Have someone hold the the selector in low pull the cable until it bottoms on the low detent. Rotate the adjuster clockwise until it touches the case, then counter to first available hole. Turn counter 5 holes and insert lock screw.
Old Aug 29, 2011 | 04:26 PM
mr.300's Avatar
thanks ill give it a try and let you know
Old Aug 29, 2011 | 05:41 PM
mr.300's Avatar
nope still same issues. any other ideas? should i pull the pan again and then adjust the cable while its open?
maybe this has no bearing but i did install a deep pan and filter spacer.
could this be the issue?
Old Aug 29, 2011 | 07:09 PM
mr.300's Avatar
well thanks for the help! after i made the adjustment to the shifter cable ( thanks coronet) i decided to try and adjust the shift linkage and wammo shifts better now than ever before. the only thing i can think is that with the tranny leaking from almost all possible spots the shift linkage was set " OK " but after i sealed it up and adjusted the shift cable it must not have been OK any more. there goes 2 days of thinking i was going to have to buy a tranny few! not to mention the bs from the wife.
floatcat
Sep 1, 2012 05:55 AM
Duece
Aug 22, 2010 12:41 AM
73plymduster
Aug 15, 2010 10:21 AM
blue 68 gts
Apr 9, 2009 02:06 AM
75powerwagon
Jul 5, 2008 04:01 PM
