nice build bad advice
Old 03-04-2008 | 02:42 PM
Factory 383hp and 440 heads were essentially the same, at least for a few years, so I doubt that the valve size is a problem
It may be more likely that the cam is way too big for what you want
Can you post some more specs?
Weight of the car? (and model)
Transmission, rear gear ratio, and tire size?
What RPM do you see at a true 60mph?
Are you running headers? a good free flow exhaust?
What is the EXACT model and specs on the cam you are running?
For example, if you took a fairly stock 383 with factory manifolds, and put in a big, 300deg, .5 lift cam, it might actually SLOW THE CAR DOWN from stock!!
1967_coronet500
05-07-2010 12:00 PM
rcknrolfender79
12-03-2009 10:39 AM
rcknrolfender79
11-29-2009 03:07 AM
Fury IIIski
09-14-2009 06:11 PM
dand97
04-13-2009 09:14 AM
Quick Reply: nice build bad advice
