No Fire Fury
Old Aug 28, 2023 | 11:25 PM
FuryIII63's Avatar
Talking No Fire Fury
I have a 1966 Fury 3 that cranks and gets spark but will not fire for some reason! I've checked the coil and points all appear in working order. I'm stumped!
Old Aug 29, 2023 | 04:47 AM
Kuvasz101's Avatar
The big 3. Compression, ignition and fuel.
You said you have ignition.
If it's not flooded, Check to see if the choke is closing. If that's ok give a spray of fuel down the carburetor and see if you get a start from that.
If it ran ok prior to shut down the timing chain could have jumped a few teeth, that's when they skip a beat on shut down.
Old Aug 29, 2023 | 11:22 AM
Lostviking's Avatar
Make sure you don't have the distributor in backwards (180 deg).
Cori Mielke
Jan 31, 2017 05:49 PM
puchie13
Mar 16, 2015 06:35 AM
Arbiter343GS
Aug 1, 2012 08:23 PM
meenaniroc
Mar 23, 2011 12:24 PM
ZedR
Aug 27, 2009 03:57 PM
