oil pan leak
Old Aug 3, 2016 | 03:45 PM
stevestefko's Avatar
oil pan leak
I have an '86 d-150 pickup. it has a 360 motor. the oil pan leaks at the front and rear. do I have to lift the motor to drop the pan? any other advice on changing the gasket and lower seals is appreciated. thanx
Old Aug 3, 2016 | 05:08 PM
I believe you do need to raise the motor, disconnect the drag link, remove the trans inspection cover. May also need to rotate the motor for the crank counter weights to clear the pan
Skynyrd
Sep 10, 2014 05:24 PM
MarkyMark12345
Apr 10, 2009 06:43 PM
dzltd02
Oct 28, 2008 08:25 AM
robertoil
Jan 25, 2008 05:34 PM
