Part number for 9 1/4 rear in B-body
Anyone know the part number for the 9 1/4 rear in a B-Body? I have been looking for awhile online and can't find any info. Before I go out and start looking at scrap yards I want to have an idea what to be looking for besides the 12 bolts.
Also to confirm that an open diff turns the wheels in different directions, and a posi turns the same way, or am I reversed?
If the posi unit is worn out though, it will act as an open carrier unit. Your best bet is to pull the cover off and look inside. Of course if you find one where both wheels turn in the same direction, you son't have to pull the cover.
I am going to take a look at on Thursday, I found three part numbers that were stamped on them: 3507890, 3507891, and 3723199. If anyone knows of any of the others for a 1973 please let me know.
My mechanic who has recently changed roles to an adviser, (not sure if he is aware that he isn't going to get any work from me that I can do myself,) said that I needed to change it. Of course I believe him, he has more experience then anyone I know, but there is the same Chevy guy I have referred to before said I should be fine. In the same sentence he will tell me the way it needs to get done, and that he has no clue on how the mopars work. He said let it break, and I always reply I prefer not to break anything while driving, especially something like that which could be potentially dangerous, or expensive if it breaks in the wrong place.
Nice, If you could check the numbers I would appreciate it, as I don't want to make the mistake I made last week and rely too much on the person selling.
Are there any numbers other then those three that fit the b-body?
I looked up the axle for 78 passenger cars out of our books, we have a lot dating back to the fifties. Anyway the 78 parts book has the part number listed for a 9 1/4 as 3507702. That is the housing package, I can find other numbers just let me know.
#25
Not sure what years they are from, just what I found when searching online. Preferably a 1977 rear, but I will take any that came off a b-body as I read from the rear diagram, that all of them are the same.
#26
So I looked up the numbers in the 1977 parts book (for some reason i thought you wanted a 78) and the numbers that you have are for the 1977 b body vehicles. It has a note in the book that the 9 1/4's will have those numbers stamped on the axle.
#28
Your welcome, finally i feel like i have helped someone. I was starting to think i was useless. hahahahaha
I read back on this thread a few post ago that you wanted part numbers for a 1973 do you want the part numbers for a 1973 axle i can try to look for them. I am sure we have that book to?
#30
Guest
Posts: n/a
does anybody know if "A" is to the housing flange or the axle flanges?
i registered to help out a friend who put a 383 in his 72 charger("B" body?).the genius blew the spider gears off the cross pin shaft in his 8.25 and did in the gear set as well. he got together the parts to rebuild it with a powertrax and new r&p but if i can find an axle that will work i'll insist he return the turd polishing parts and get a stronger axle.
forgive this 65 mustang driver for knowing little about mopars.can you tell me what the best donor canidates are for an upgrade?(apologies to the O.P. for the thread jacking)
