Please help my 73 Satellite wagon run right
Old Dec 12, 2009 | 07:18 PM
Mopar_71's Avatar
Hey 73SatWag,
That sounds like your fuel line is getting vapor lock at the rubber fuel line before the carb. (when the fuel boils)
Or you might have debris in your gas tank that is clogging the strainer in your tank.
If you can, get a gauge that reads positive pressure in PSI. Hook it up to the fuel line right before the carb and crank the engine over. You should have at least 3-7 PSI.
You could also get small portable 2-5 gallon gas can and hose that plugs into the inlet of your fuel pump and see how that runs. (this will tell you if you have a clog before your fuel pump.)
You could disconnect the choke linkage for troubleshooting purposes. It could be your dash pot.
It does seem like a fuel problem.
Good luck and keep us updated
Mopar_71
Old Dec 14, 2009 | 01:55 PM
Frank the Tank's Avatar
I have a 74 satellite and my car had a similar problem. Other than vapor lock, check the idle mixture screws. With the engine warmed up and turned off, remove the caps from the two screws and turn clockwise until they seat. Then turn counterclockwise one and a half turns. Start engine and turn screws only a 1/16 of a turn at a time for adjustments. This can be why the idle raises after the choke disengages. It can be running to rich.
89 Dodge ram
Mar 22, 2017 07:55 AM
70Coronet
Apr 11, 2012 05:59 PM
uturn
Jul 13, 2010 09:02 AM
repoman
Mar 27, 2010 09:45 AM
siliconcrunch
Dec 1, 2008 10:57 AM
