Polara Fender Tag Help?
Old Jan 26, 2011 | 10:22 PM
PatsPolara's Avatar
Hi, does anyone have a book to decode fender tags? I just got a '64 Polara 500 and want to see what options it came with. Here's what the tag reads:
1234567890
(BLANK)
AB D F HJK MNPQR T
52 4 1 566 38205 4
S0 NUMBER BDY TRM PNT
0207 2112 645 P4X SS
Thanks in advance!
Old Jan 27, 2011 | 12:52 AM
MercuryDon's Avatar
SO(0207) FEB 7TH,
PRODUCTION #2112
BDY(645) POLARA 500 CONVERTABLE
TRIM(PX4)BLACK
PNT(SS1) IVORY
My Book only decodes the one line.
Old Jan 27, 2011 | 08:51 PM
PatsPolara's Avatar
Thanks Don, I appreciate it. I guess the number "1" is missing from my paint code, the tag only says "SS" not "SS1." Do you have any idea were I can decode the other line? Trying to see what the original motor was, among other things...
Old Jan 27, 2011 | 10:42 PM
MercuryDon's Avatar
Base Engine in a Polara 500 was a 305 HP 383 2Bbl Premium fuel with single exhaust.
Optional engines were
330 HP 383 4Bbl. Duel Exhaust
365 HP 426 4Bbl.
415 HP 426 Max Wedge 2x4Bbl 11/1 comp.
425 HP 426 Max Wedge 2x4Bbl 12.5/1 Comp.
If the original engine is there it will be stamped on a machined surface on the block just behind the water Pump with the engine ID and prodution Date .
Your Vin should start out with a
6(V8)
3(Polara)
Then assembly plant (1 of the following)
2,3 Detroit
5 LA
6 Newark
7 St Luis
digits 5-10 Sequence number
Old Jan 28, 2011 | 03:15 PM
PatsPolara's Avatar
It's got a 361, I have to go back and check the date code. I found a decoded body tag online, some of the info matches mine so I was able to decode these letters:
H5 FRONT HEATER
M3 BACK UP LIGHTS
N8 DUAL JET WINDSHIELD WASHER
P2 OUTSIDE LH REMOTE MIRROR
T4 70 AMP HD BATTERY
BDY 6=DODGE V8 4=POLARA 500 5=CONVERTIBLE
TRIM P=PREMIUM (BUCKETS) 4=VINYL X=BLACK?
Still have 8 different letters to decode, including the engine...
Old Jan 28, 2011 | 04:23 PM
MercuryDon's Avatar
You might wish to check this page out http://auto.howstuffworks.com/1962-1....htm/printable
Old Jan 29, 2011 | 02:47 PM
PatsPolara's Avatar
Thanks Don, that's a great article. Here is the decoded tag, special thanks to Len:
AB D F HJK MNPQR T
52 4 1 566 38205 4
A5= TORQUEFLITE 727
B2= POWER BRAKES
D4= POWER WINDOWS
F1= AM RADIO
H5= FRONT HEATER
JK66= BLACK CONVERTIBLE TOP
M3= BACK UP LIGHTS
N8= DUAL JET WINDSHIELD WASHER
P2= OUTSIDE LH REMOTE MIRROR
QR05= 383 2BBL
T4= 70 AMP HD BATTERY
SO= FEB 7, 1964
PROD NO= 2112
BDY: 6=DODGE V8 4=POLARA 500 5=CONVERTIBLE
TRIM: P=PREMIUM (BUCKETS) 4=VINYL X=BLACK
PNT: SS=IVORY
Brian C.
Aug 17, 2013 03:18 PM
Randy Bonds
May 10, 2013 11:45 AM
67 Fury
Feb 12, 2010 08:17 PM
MarkyMark12345
Mar 16, 2009 01:02 PM
frankie
Nov 25, 2008 11:53 PM
