Power steering pump - Rebuild or Replace
Old Aug 17, 2009 | 02:03 PM
heminate's Avatar
My 1971 Dodge B300's power steering is completely dead. There is fluid in it, but no power. I noticed there is a rebuild kit at the parts store for about $25 that has some seals, while a whole pump is $155 - $8 core.
I have no experience with repairing power steering pumps, I've never had a problem with them in the past, except for them leaking.
Anyone here have experience repairing or replacing these pumps? Should I go to the boneyard and get one?
Old Aug 17, 2009 | 02:34 PM
Crazy4Carz.Com's Avatar
The boneyard is not a bad idea. I doubt I would attempt the rebuild myself unless I was trying to keep an all original numbers car all original.
Old Aug 17, 2009 | 08:03 PM
theomahamoparguy's Avatar
Boneyard could be a viable option, match them up and look for leaks or;
Shop around some more. Hopefully you have a GM style pump. You should be able to just buy the "pump" part of the unit and just swap over your resevoir {spelling?} and your pulley, this should cost less.
Iff you have the other style It will cost more. {u most likely dont}
If yours is just leaking around the edge where the pump attaches to the resevoir, that is just an o-ring that is bad, easy to change.
If it is leaking around the front pulley shaft, then you need to replace the unit {easiest way to fix}
Your local auto parts store should be able to swap over the pulley for you.
Be careful removing the lines and installing them, you dont want to strip these threads. Make sure they thread by hand a ways when installing.
Just my two cents worth. {the pumps are not complex}
Old Aug 17, 2009 | 08:07 PM
I just realized yours is not leaking but no pressure. oops. Yeah look for another
or it may just be clogged.
64fury
Apr 7, 2014 12:02 PM
raycan2
Dec 15, 2013 09:49 PM
66Newport
Apr 22, 2013 04:43 PM
Snoblor
Apr 21, 2013 03:11 PM
brucewon
Apr 11, 2010 08:49 AM
