rusty gas tank?
Old Jul 24, 2009 | 09:16 AM
Morrigan_Aria's Avatar
Hell kitten
I've seen kits for the tank dip and sealant at several retailers both online and at brick and mortar stores. You could also contact a radiator shop and they can chemically boil it out for you.
I was in the same boat not long ago with my Belvedere.
The problem with dipping your tank? You might find it has holes in it. Then you are out the cost of the dip or chemicals (not to mention they seemed pretty nasty; I wouldn't use them at home, personally, because we have a well and I don't want that in MY drinking water)...and then have to replace the gas tank anyway.
After alot of research and thinking, I just replaced the tank. Seemed more time expedient and less (potentially) outlay in the end. So now I have a tank that should last another 40 years and no worries!
Old Jul 24, 2009 | 09:29 AM
scotts74birds's Avatar
X2 I've had problems with the coatings they use in my motorcycle tanks. Go new if possible.
Old Jul 24, 2009 | 11:02 AM
Crazy4Carz.Com's Avatar
I've used the coatings with success. The most important thing is to FOLLOW THE INSTRUCTIONS and all will be fine. This is only if you cannot get a new tank. Don't do the fuel cell thing. the gas filler will be a pain in the ***, and will turn off future buyers.
Old Jul 24, 2009 | 05:19 PM
try to replace the tank
lgad
Jul 25, 2011 08:06 AM
8287rams
May 3, 2009 06:45 AM
71RR08
Aug 25, 2008 08:40 PM
Monacoman
Jul 6, 2008 11:23 PM
Monacoman
Jul 5, 2008 11:15 AM
