sagging drivers side door
Old Mar 24, 2009 | 07:30 PM
68 Sat's Avatar
Any advise for a sagging drivers side door? It sags about 1/2 to 3/4 inch.
Attached Thumbnails sagging drivers side door-dsc05197.jpg   sagging drivers side door-dsc05559.jpg
Old Mar 24, 2009 | 07:35 PM
craveman's Avatar
Senior Member
have you tried new hinge pins and bushings. mine had the same problem and it was only a 10 dollar fix. also have you had one corner of the car jacked up a lot for some reason. if so jack up the opposite corner a few times and let it set for about 10 mins each. after i replaced my rear wheel cylinder on my fifth today i had to jack up the drivers side front cause the door caught on my fender but its all ok now.
Old Mar 25, 2009 | 07:23 PM
68 Sat's Avatar
ok i ordered the hinge pins and bushings. Any advise on how to install them?
Old Mar 29, 2009 | 03:56 AM
craveman's Avatar
Senior Member
in my car i could just push them up from the underside with pliers but im not sure if you can see your hinge pins or not
MrChris
Oct 16, 2013 08:30 PM
fletchy38
Jun 16, 2012 07:37 PM
bremereric
Mar 18, 2012 08:56 AM
moparjohnson123456
Jun 14, 2011 01:36 PM
1969GTX
Apr 5, 2008 06:20 PM
