Simple Tranny Question
Old Feb 11, 2011 | 05:59 AM
afro's Avatar
A904.... Will it work on an LA series 360? Keep in mind I'm not trying to find a tranny to abuse.
Description is:
"1977 Chrysler Plymouth Pass. Transmission A.T., 6-225, A904, Std Duty"
Thanks for any feedback
Old Feb 11, 2011 | 07:09 AM
Description is:
NOPE. In the older A904/ 727 transmissions (ignoring the newer overdrive variations)
there are, in the 60's and later engines, SIX bellhousing configurations.
A 904 and 727, for SLANT SIX ONLY (that's 2)
A 904 and 727, for SMALL BLOCK ( 2 more)
A 904 and 727 for BIG BLOCK (six total)
A 904/ 727 easy to tell apart.
A 904 has straight sided pan edges, with one corner cut off
727 has a rounded bulged on the passenger side of pan edge
Engine bell fit is more difficult, might be diagrams on th' www
and sure enough, Gargoile comes up with:
[img]http://dartstechsite.com/transmission_bells.jpg[/iimg]
Old Feb 11, 2011 | 07:55 AM
afro's Avatar
So my understanding is I need to go for a 727. Fit won't be an issue as I'm having the firewall and tranny tunnel built to fit.
Old Feb 11, 2011 | 03:48 PM
No, you can use either a 904 or 727, but it has to fit your block.
Old Feb 24, 2011 | 12:41 PM
bboogieart's Avatar
You will need to find a transmission that will fit the block, and the 225/6 won't. You need the la small block unit, but you don't need a 904 so get what you can find for a good price. Both will live behind your 360. You should be able to find one in an older 80's truck or van in local junk yards or classifieds. I am guessing you are asking because you have found the /6 unit for sale. Make sure the torque converter is weighted the same as the motor. i.e. internal or external ballance.
70Coronet
May 16, 2012 04:45 PM
merkfalc
Jun 30, 2011 05:49 PM
B_Carpenter89
Dec 28, 2009 03:42 AM
mhonkieys
Sep 18, 2009 04:04 PM
soulkithchen63
Apr 6, 2008 08:12 PM
