is there a brake pedal spring?
1970 340 cuda. the resting position of the brake pedal makes the brake light come on. if i pull the brake pedal up, the brake light goes off. this just happened. it didn't used to be this way. i believe the pedal stayed up and the brake light was off and it came on only when you applied the brakes like normal.
