is there a brake pedal spring?
Old Apr 18, 2013 | 09:43 PM
cudagecko's Avatar
1970 340 cuda. the resting position of the brake pedal makes the brake light come on. if i pull the brake pedal up, the brake light goes off. this just happened. it didn't used to be this way. i believe the pedal stayed up and the brake light was off and it came on only when you applied the brakes like normal.
Old Apr 18, 2013 | 10:06 PM
70redbee's Avatar
I don't know about a spring but I believe the switch on the pedal can be adjusted. Hope this helps.
Old Apr 18, 2013 | 10:33 PM
PURPLE HORONET's Avatar
No spring, the brake fluid is the spring... When you push the pedal it pushes the fluid in the line and thats what compresses the brake pads.
Whats the problem
Old Apr 19, 2013 | 08:01 PM
cudagecko's Avatar
the problem is that the brake pedal does not stay up. the way it currently rests, the brake light comes on. in other words, the brake light is always on.
Old Apr 20, 2013 | 08:24 PM
mikerp76's Avatar
try adjusting the switch. or replacing it. it may have slid in its mount so it isn't making contact with the pedal to shut off the lights.
cudagecko
Apr 19, 2013 02:54 PM
2thpic
Apr 6, 2012 12:20 AM
johns cuda shop
Apr 22, 2011 05:01 AM
tcherrone
Apr 15, 2011 05:03 AM
1966DartConvertible
Sep 21, 2010 06:28 PM
