Timing mystery on my 65 383
Old 04-29-2010 | 05:48 AM
sweeperking's Avatar
Question Timing mystery on my 65 383
Kinda new here so bear with me not sure how much detail to provide. On my 65 dodge I pulled the distributor making sure of correct rotor position in relation to #1 cyl and aligning the timing marks on dampner prior to pulling. After pulling distributor I decided to to a timing chain and gear replacement (why this is all done is a long story, don't ask). After tearing down I found the mark on the crank gear at 12:00 where it should be but no sign of the mark on the cam gear. I rotated the crank 360* which rotated the cam 180*, now the marks lined up perfect and the new set went together no problem. To compensate for this I installed the distributor 180* from the position that I removed it (or so I thought, this is the mystery) I'm not sure why the cam was 180 off to begin with I thought maybe I screwed up pulling the distributor (not). After reinstalling the distributor now the rotor is under #6 on the cap. Car is used so I thought maybe the distributor was replaced and reinstalled 180 out and plug wires were repositioned to compensate but according to my motor manual everything is correct so I repositioned the distributor back the way I orginally removed it but now I'm scratching my head because I did that 360* rotation of the crank after teardown. The way I figure the gears and chain have to be correct or they wouldnt go together (crank is keyed and cam is dowled) I havent tried to start the motor yet I'm trying to figure this out first any suggestions?
Old 04-30-2010 | 07:04 AM
rdrunner1974's Avatar
timing
Install the timing set with the crank mark at 12:00 and the cam at 6:00 then rotate the crank 360* so the crank is at 12:00 and the cam at 12:00 and install the distributor with the rotor pointing to #1 You should then be at an area close to starting, rotate the dist. slowly while cranking and then use a timing light to set it
Old 04-30-2010 | 07:30 AM
340SIXPACK's Avatar
Junior Member
hello ,dont know if i understand what u did but ,the rotor should point to # 1 on compression stroke,when you took the cover off was the marks on the two gears pointing away from each other or at each other??? i have seen where the rubber on the dampner has let the outer mark move on the pully so # 1 the vibration dampner is wrong take #1 spark plug out and see if it is at the top of the cly and where your mark is on timing cover
Old 04-30-2010 | 08:57 AM
340sixpack, to answer your question the marks on both crank and cam were pointing straight up (12:00 position) with the no 1 cyl at the begining of the fire stroke (TDC between compression and power) I proved this by pulling the valve cover on the left bank and watched no 1 cyl while rotating the crank sooooo..........rdrunner1974, you are correct sir, just not sure why. I'm kinda old school here but I always thought that when the timing marks line up (cam on the bottom and crank on the top) that no 1 cyl should be ready to fire but not in this case actually in this situation no 6 is ready to fire.
labradorian70
09-24-2014 10:44 AM
Gorts 5th
12-19-2012 05:52 PM
Foedoe
05-17-2011 06:34 AM
Steve Schmidt
06-21-2009 06:51 AM
kurtw
12-27-2008 05:02 PM
Quick Reply: Timing mystery on my 65 383
