valve train problems 318
Old 03-27-2011 | 02:16 PM
combine450@yahoo.com's Avatar
Heres what i have. I recently pulled the 318 out of my 1991 dodge ram. I decided to go with a carb instead of throttle body. I went with comp cams 20-612-9 and the compliant valve springs. I left everything else stock on the motor as far as rocker arms, lifters, push rods, etc. keep in mind this is a roller motor. i got it all together and it bent one of my pushrods and pushed it thru the rocker arm. does anyone no my problem??? thanks
Old 03-27-2011 | 03:39 PM
Offhand, I'd guess that either you somehow got the one pushrod out of place, or you are having "coil bind" problems
Old 03-27-2011 | 06:21 PM
does this cam sound like it should work for this motor?
Old 05-29-2012 | 01:36 PM
Gorts 5th's Avatar
sounds like u got coil binding problems a lot of big lift cams require head work "spring seat "
needs to be machined
i had this prob on a set of 360 heads didnt do the type of damage u ended up with but they made noise "clicking" i could see the springs bind with car off and valve cover off
Old 05-29-2012 | 02:25 PM
I doubt that it's coil bind, most likely valve retainer contacting the valve guide. The 318 cams were .390", .420" tops on the newer ones like yours. I've measured a ton of these and .450" at best anything larger like your .480" and you'll hit. Was the damaged one an exhaust? We just did my son's a couple of days ago and he took off .130" to accomodate a positive seal and .484" lift.
If you have magnum rockers it will have even more lift than the advertised with 1.5's.
Old 05-29-2012 | 03:25 PM
PK1's Avatar
PK1
Usually a push rods are to long will do that. Are you reusing your stock PR with the new cam? And what heads and rockers are you using?
jimiheadstone
10-03-2013 08:25 PM
74Runneer
12-24-2012 02:09 PM
PK1
16
08-10-2011 07:03 PM
Mopar_Fan
11-06-2010 12:55 AM
bschubarg
04-10-2007 07:08 AM
Quick Reply: valve train problems 318
