Wheel help
Wheel help
OK so well i figure i have a 5x3/4 bolt pattern however (68 fury btw)
what im thinking is about what size i can go with. Im not trying to have a donk or anything retarded, however im thinking 20s will be too small for such a beast of car and the wheel wells will engulf it,however upside to 20s i can have more tire = better ride
question is 2 part , Would 22s just be overdoing it? i see Foose makes them so obviously it isnt too ridiculous of a size ..but i think id need "rubberbands" which i dont want or would i be able to fit 22s WITH a decent amount of rubber....
but either size i go with what should be the offset? and how wide can i go without doing any fender rolling ETC?
Guest
Posts: n/a
It all comes down to your personal preference, In my humble opinion anything larger than a 17" rim on a muscle car looks cartoonish & hokey. & ride quality will be terrible. With 22" rims your sidewall will be so short, you'll have to upgrade your dental plan, 'cause every time you hit a set of RR tracks all your teeth are gonna fall out! a 68 Fury should have a 5 on 4 1/2 bolt pattern btw.
1010tires.com can help you choose tire sizes for different rims. if you go with the 20's you could use 245/40/20's there about a half inch taller overall than 205/75/15's if thats what it came with. you would be going 1.2mph slower than what your speedo says though.
