1970 d100 engine mount issue
Old Oct 4, 2012 | 02:43 PM
jdhyatt21's Avatar
Hi, so i just finished rebuilding a 360 for my 1970 d100. When i went to reinstall the engine, i found that the motor mounts did not lay flat on the frame brackets. I've double checked the brackets on the engine to be sure they were in the right configuration and they were. I did replace the front cross member while the engine was removed due to some unnecessary cuts the previous owner had made. So my question would be, when i changed the cross member could i have distorted the front frame rails enough to cause this engine mount miss alignment, or is there some thing else that i missed?
Old Oct 4, 2012 | 05:30 PM
Make sure the insulators are not in backwards
Old Oct 4, 2012 | 09:18 PM
jdhyatt21's Avatar
Checked the isolators and it doesn't seem to make a difference which way they go. Could shimming the transmission mount make a difference?
Old Oct 5, 2012 | 01:27 AM
Has nothing to do with the trans mount There is a right and wrong way for the insulators to be installed.. Make sure the dimple in the insulator aligns with the indent/hole in the motor mount. I have done it myself.
Old Oct 5, 2012 | 02:45 PM
jdhyatt21's Avatar
I'm not sure what you mean by dimple. The insulators i'm using are flat on the top surface other then the one stud in the middle that connects the insulator to the motor mount bracket.
Old Oct 5, 2012 | 04:00 PM
show the other side of the mount
Old Oct 5, 2012 | 09:22 PM
jdhyatt21's Avatar
Here is the opposite side of the mount.
Old Oct 6, 2012 | 01:31 PM
I don't know what you have? Diagram at Rock auto show's it to be the same. Could your motor mounts require the newer type of insulator ? OR the K frame is a newer version that requires the newer insulator
Old Oct 6, 2012 | 09:52 PM
I wish to heck I knew. Only advice I can give you is to find a pickup in your area and look it over. I'm not sure, but I think these mounts were the same for years and years.
Old Oct 9, 2012 | 11:39 PM
jdhyatt21's Avatar
Ok i'll see what i can find, thanks.
Old Oct 10, 2012 | 01:29 AM
71 they listed both types of mounts 72 only the newer style take a look ..
http://www.rockauto.com/
There not expensive I would get a pair and try it !!
http://www.rockauto.com/getimage/get...nchor/2265.jpg
Old Oct 14, 2012 | 11:52 PM
jdhyatt21's Avatar
I found the problem. Turns out upon closer inspection the driver side engine mount bracket had been modified by the previous owner to allow the mount more movement side to side. I was able to find another driver side mount locally so problem solved.
19newport72
Mar 27, 2024 06:44 PM
Duece
Aug 22, 2010 12:41 AM
smackhonda
Jun 2, 2010 04:04 AM
Dizzle
Apr 29, 2010 09:26 PM
aqualung
Sep 24, 2007 02:16 PM
