1971 383 cam and lifters
Old Jan 7, 2016 | 11:21 AM
Hockeyger3's Avatar
hi everyone, I am looking for some advice on a cam i am looking for something that is streetable but want to make some power. I am wondering what you all suggest or have tried and liked . thank you in advance. Gerald
Old Jan 8, 2016 | 07:57 PM
red67's Avatar
i found a good list of Chrysler 300 cams. the one to the far right is for a 300 L 413 360 hp. the same engine in a newyorker was 340 hp. at .389 lift, 248 duration. the 300 L .430 lift 268 duration. but still very street able, good idle. and same MPG as a newyourker. and in a 1965 300 L 4,200. lbs stock. turned a 16.00 sec 1/4. but DO note this 300 L is not meant to be a full out race car. it is a gentleman's luxury performance car. check out this list. http://www.chrysler300club.com/tech/cam/gk.html
Old Jan 8, 2016 | 09:57 PM
red67's Avatar
383 cam
this may not help but its just for reference. the 300 L i talked about i sold to my dad. the 413 had 10.00 compression. dad was rebuilding it 1977. the good gasoline is gone. but dad found out that they used the 413 in trucks in to the early 70s. with a 7.5 piston. that was a bolt in. weight, size, was the same. and we had an original new cam. the 413 run very good on 7.5 CR.
Old Jan 11, 2016 | 03:31 PM
demetri's Avatar
You need to add more info on what you need to do with the car. Weight and rear end ratio help.
I got a cam and lifter comp cams with 268-288. .477-.488. This is one or two steps above the standard HP cam in 68. In my case, I wanted a cam that retains low end torque to move a BIG car around with highway gears, while still having strong mid and upper range. I also had some mild head work done with bigger valves. This is on a 440. I am not done tuning it yet (I cannot get the mixture rich enough), so I am not sure how strong the mid range will be, but I have evidence that the upper end will be good, and low end torque is sufficient. Idle reasonable.
Old Jan 13, 2016 | 05:49 PM
The 268s have always been my favorites in a Mopar engine.
maca
Jul 17, 2014 03:13 PM
70newport
Mar 20, 2014 07:52 AM
1968GTX
31
Feb 19, 2014 10:00 AM
1923tbucket
Apr 3, 2013 02:15 PM
rc-ltu
Jun 3, 2011 08:57 PM
