1975 Cordoba 360 Build Tips
Old Jul 27, 2011 | 07:18 PM
Good_Ol_Boys_Garage's Avatar
Question 1975 Cordoba 360 Build Tips
New To The Mopar World But Not Engine Builds
Looking For Some Info On Good Set-up For A Street/Strip 360 Engine
Low Mileage, None Smoking Engine
Looking For Cam Picks/Intakes Other Stuff
Any Ideas
Old Jul 27, 2011 | 08:16 PM
Cordoba is a heavy car ! You probably have a thermoquad carb ? If it is working it is fine. With stock gearing 2.91- 3.21 ? Just a good set of dual exhaust Very mild cam will help . IF you are going to put 3.91 gears or ? that will change everything
Old Jul 28, 2011 | 10:34 AM
looking at keeping the rear gear as it stands for now
any part #s for a good cam kit?
Old Jul 28, 2011 | 03:12 PM
theomahamoparguy's Avatar
how about this: Summit racing Part #SUM-K50052.
...summit cams kits are actually very good quality, made for them by melling, and you cant beat the price $145 for the cam and lifter kit. This cam is .454 lift.
this would give the Cordoba plenty of grunt and some top end.
Old Jul 28, 2011 | 05:48 PM
With The Duration 272/272, Lift .454/.454 We I Run Into Other Problems Down The Road? Or Needed Mods?
Anyone Using This Cam?
Was Looking At The Edelbrock 2177 - Edelbrock Performer-Plus Camshaft Kit
Old Jul 30, 2011 | 03:23 AM
I think you would get by with some new springs. Should have no problems with coil bind or piston to vavle. stock 360 pistons were down in the hole If you were worried just drop down to the next size smaller. I think it is a .440 lift. thats what I got in my "truck" motor.
76 Doba
Feb 5, 2013 05:45 PM
Aesthetikz
Jan 21, 2013 04:57 PM
MAGNUM GT XS22L9R
Mar 29, 2011 02:54 AM
MAGNUM GT XS22L9R
Mar 25, 2011 04:38 PM
daveravid
Feb 20, 2011 05:12 AM
