1979 lil red express 360 is having issues with timing
I bought a lil red express with a 360, that the previous owner had "modified" and I am trying to even it out a very rough idle. The last owner put in a purple shaft 284lift/484dur, a Wieand Stealth intake, Edelbrock 750 (which I just replaced with an electric choke 600), long tube headers ,and a set of used J heads.
Now the only way I can start the truck is if the timing is set advanced to 34-36 at idle with a total advance of 44. The idle is very "loopie" and it is hard to start when hot. If the truck is running I can bring the timming back down to 19-20 at idle but no lower and it will run fine at that, however I can not restart it there. I have to bring it back to 34-36 advanced. Sounds like something is not aligned right (cam, timing chain, ???) when he reassembled the motor. I am not a motor builder but would like to know what I would be getting into to have this fixed. Any advice? https://cimg9.ibsrv.net/gimg/moparfo...462e35e973.jpg |
If you don't have one, you need a distributor that will lock in the total advance. Lock it in at 35 degrees total advance at 2000 rpm with the vacuum advance plugged.. Then you can reconnect and set the vacuum advance.
You got the lift and duration swapped in your info. But we get it :)
Sounds like you sound be on the rite track. Maybe the cam is installed wrong, like off a tooth or 180* out? Check the Vacuum reading. I bet its way low, and if you have power disc brake. the brake are probably kind of lame and dont work too well? I think the car is too small for that cam. Try the other carb back on it and see if its better? Also, If its the low compression engine? Its a tough tune !!!! Just an FYI. I had to pull that cam and still have it on the shelf. |
(Post 143404)
Originally Posted by Drag Pak
(Post 143415)
It certainly is! An absolute must is to enlarge the idle syphon tubes of any carburetor you may choose to at least 0.043 to get enough idle fuel for idle mixture adjustment. And that takes a bit of skill and some drilling (and tapping and plugging "Holley").
But tuning some of this stuff that was so lean to begin with even back when we had leaded fuel has become a pure nightmare in it's self. You almost have to tune it as if your tuning something that is running them on Alcohol...lol |
And he'll need at least a 10" converter to make it street comfortable, even if he can do the advanced carburetor work. Or ditch the cam.
Ok, I said I was not a builder as evidence of this post.
ALL is good. I did not know I was supposed to plug the vacuum advance on the disti when I time the motor. Once I did that it is right at 16deg. Also is was VERY lean. I pulled the plugs and they were white... I enriched the idle mixture and now the thing is running much better and I am not worried about burning a valve. Also The tourqueflite throttle position linkage was not hooked up. I got it back in order and now it shifts great and kicksdown. It is a much happier truck.. Thanks for the advice and putting up with a newbie. |
(Post 143437)
Originally Posted by Dane Trask
(Post 143440)
ALL is good. I did not know I was supposed to plug the vacuum advance on the disti when I time the motor. Once I did that it is right at 16deg. Also is was VERY lean. I pulled the plugs and they were white... I enriched the idle mixture and now the thing is running much better and I am not worried about burning a valve. Also The tourqueflite throttle position linkage was not hooked up. I got it back in order and now it shifts great and kicksdown. It is a much happier truck.. Thanks for the advice and putting up with a newbie. Glad you got it running better... Lets keep making you and it better... :) :) |
(Post 143442)
Thanks for the great subject,,,, Hope you don't think we where bagging on you... That is not the case at all... We just throw things out and hope something gets you back up and running so that you are happy.
When I ran that cam it liked 20 initial and 14 centrifugal.
(Post 143449)
I also figured out I had a low fuel pressure and a percolating issue. The fan clutch was wasted. New fan clutch, thermal isolator between carb and intake, thermal sleeve over fuel lines and a new fuel pump. The truck is now running and starting great. |
(Post 143539)
That's right where I settled on. Any lower and I have hard starts, higher I lose my lowend torque. Thank you very much.
(Post 143548)
Making Great progress !!!! AWESOME
Glad you have found your problem... Mopar on !!!
