Mopar Forums (/forums/)
-   -   340 motor cam (https://moparforums.com/forums/f81/340-motor-cam-16328/)
mahd Dec 16, 2013 05:16 PM
340 motor cam
Hi again, i didnt buy that other 340 engine with the piece broken off but i found a new motor it a 70 340 bored over 60 with..292 duration/509 lift camshaft.Rhoads lifters. 8 quart oil pan.LD340 intake manifold. Is this a good street friendly motor, what carb would you put on it i have a 600 cfm holley but i think its too small.
Thanks for your input
Coronet 500 Dec 16, 2013 05:28 PM
Friendly? Fun for sure with a clutch or hi stall and 3.55 or up gear. Yee haw.
RacerHog Dec 16, 2013 06:09 PM
Give the 600 a try..... But you might find it will need a 750 cfm holley...
Just my 2 cents..
TVLynn Dec 16, 2013 06:25 PM
Needs a Hi stall converter. If the price is cheap Go for it The block is at the end of it's life with .060 over bore
RacerHog Dec 16, 2013 06:26 PM
I agree...Lots of untold.... ;)
Drag Pak Dec 16, 2013 06:59 PM
^^^^^^What they said!! No biggger than a 10" converter and no smaller than a 750 cfm, but 800 would be even more fun!
moe7404 Dec 16, 2013 08:48 PM
why do you need a cam that big? the O.E.M. cam for 68 was not that big. i have to guess you want a full out race car. and thats fine. sounds like a lot of fun. 340, 1968 Camshaft
4-Speed
.444 /.453 Lift ~ 276*/284" Duration ~ 52* Overlap
Automatic
.430/.444 Lift ~ 268*/276* Duration ~ 44* Overlap ~ 114* Center-Line
this 4 speed cam was first AND last year it was used O.E.M.
440roadrunner Dec 17, 2013 10:02 AM
Originally Posted by mahd (Post 112794)
Is this a good street friendly motor, t
Define "street friendly motor."
With that cam, that is the furthest thing from "street friendly" in my book you could get
You need LOW gears
heavy clutch
REAL high stall converter
light vehicle weight
Buy a gas truck to follow you around.
RacerHog Dec 17, 2013 10:24 AM
This is What I'm talking about.... :)
Drag Pak Dec 17, 2013 12:40 PM
Street Freindly = If you can't tune it, Don't buy it!
I used the 292/509 in a low compression 318 with 2.02 T/A heads, Six Pak, 10" converter, MP Electronic distributor, 3.55:1 gears 3600lbs = 14.82 1/4 mile daily driver as a mule engine for 17,000 miles. It took a little tuning at first but ran meticulously.
As always, it's all in how commited you are to the tuneup.
