340 motor cam
Old Dec 16, 2013 | 05:16 PM
mahd's Avatar
340 motor cam
Hi again, i didnt buy that other 340 engine with the piece broken off but i found a new motor it a 70 340 bored over 60 with..292 duration/509 lift camshaft.Rhoads lifters. 8 quart oil pan.LD340 intake manifold. Is this a good street friendly motor, what carb would you put on it i have a 600 cfm holley but i think its too small.
Thanks for your input
Old Dec 16, 2013 | 05:28 PM
Friendly? Fun for sure with a clutch or hi stall and 3.55 or up gear. Yee haw.
Old Dec 16, 2013 | 06:09 PM
Give the 600 a try..... But you might find it will need a 750 cfm holley...
Just my 2 cents..
Old Dec 16, 2013 | 06:25 PM
Needs a Hi stall converter. If the price is cheap Go for it The block is at the end of it's life with .060 over bore
Old Dec 16, 2013 | 06:26 PM
I agree...Lots of untold....
Old Dec 16, 2013 | 06:59 PM
Drag Pak's Avatar
^^^^^^What they said!! No biggger than a 10" converter and no smaller than a 750 cfm, but 800 would be even more fun!
Old Dec 16, 2013 | 08:48 PM
moe7404's Avatar
why do you need a cam that big? the O.E.M. cam for 68 was not that big. i have to guess you want a full out race car. and thats fine. sounds like a lot of fun. 340, 1968 Camshaft
4-Speed
.444 /.453 Lift ~ 276*/284" Duration ~ 52* Overlap
Automatic
.430/.444 Lift ~ 268*/276* Duration ~ 44* Overlap ~ 114* Center-Line
this 4 speed cam was first AND last year it was used O.E.M.
Old Dec 17, 2013 | 10:02 AM
Originally Posted by mahd
Is this a good street friendly motor, t
Define "street friendly motor."
With that cam, that is the furthest thing from "street friendly" in my book you could get
You need LOW gears
heavy clutch
REAL high stall converter
light vehicle weight
Buy a gas truck to follow you around.
Old Dec 17, 2013 | 10:24 AM
This is What I'm talking about....
Old Dec 17, 2013 | 12:40 PM
Drag Pak's Avatar
Street Freindly = If you can't tune it, Don't buy it!
I used the 292/509 in a low compression 318 with 2.02 T/A heads, Six Pak, 10" converter, MP Electronic distributor, 3.55:1 gears 3600lbs = 14.82 1/4 mile daily driver as a mule engine for 17,000 miles. It took a little tuning at first but ran meticulously.
As always, it's all in how commited you are to the tuneup.
Typhoon213
Jun 13, 2013 05:27 PM
Mr.Duster
Jul 18, 2011 12:00 PM
Red Devil
Mar 24, 2009 06:53 PM
bad_karma
Aug 28, 2008 02:03 PM
henryj
Jan 5, 2008 08:46 AM
