340 with ported X heads what cam?
Old Jun 11, 2013 | 10:11 PM
Typhoon213's Avatar
I just recently stumbled onto my dream car a 1972 dodge demon. I have a 340 I had built a while back that has ported X heads with larger intake and exhaust valves. It has the LD340 intake which is fine for now. On the Dyno is was 430hp with a basically stock street camshaft. I'm looking to increase that to more of a strip street cam that will flow a lot more, as well as change it from solider lifter to hydraulic. The car will be driven to town and around, but I would like max high RPM power and obviously that lopey sound as long as it doesn't die at the stop lights as well as have zero vacuum pressure. Also should I look into replacing the LD340 intake or is that a good start? Any suggestions are greatly appreciated.
Old Jun 11, 2013 | 10:19 PM
Keep the LD340 It is a very good manifold
If it has solid lifters ? You need to check and find out what cam it has. ALL factory cams are hydraulic
Old Jun 11, 2013 | 10:51 PM
Typhoon213's Avatar
COMP Cams Xtreme Hi-Lift Camshafts 20-227-4
This is the cam that I was looking into. I wont know what cam is currently in it until I pull the engine apart for a reseal and new paint. Also it will be a 4 speed car, with a dana 60 currently has 5.13 gears. Most likely will run 4.56's in the end, taking suggestions on that as well thanks all.
Old Jun 13, 2013 | 02:55 PM
68er's Avatar
I have a LD340 on my 340... Love the intake
Old Jun 13, 2013 | 05:27 PM
I like Comp Cams. Go to their website and download their free camquest software and input your info. I will select from good, better and best cams and tell you what you need.
734406pack
Jun 24, 2015 03:54 PM
74Runneer
Mar 11, 2013 08:03 PM
Boneheadjoe
Sep 30, 2012 06:10 AM
Barfly
Apr 17, 2011 09:15 AM
Jay
Jun 3, 2010 10:24 PM
