360/408 Head Bolt Sealer ?
What sealer do you guys us on head bolts that go into the water jacket ? -- It's a 360/408 stroker with Edelbrock aluminum heads. Of course it's a steel block. I'm using ARP STUD bolts and Cometic head gaskets. -- Thanks
I use the GM stuff or the Permatex...
http://www.truckpartshq.com/permatex...VEkaAg4O8P8HAQ http://paceperformance.com/i-5133797...9-oz-tube.html :) |
I was under the impression that 340 / 360 head bolts were "dead ended" in the block Some 318s are wet
Yep -- Thanks
Originally Posted by DDodger
(Post 130328)
Bob's absolutely correct. Permatex Thread Sealant with is PTFE in a tube is your best bet, T-tape no.
| All times are GMT -7. The time now is 08:28 AM. |
