360 build
Old Jan 23, 2017 | 05:50 PM
devo's Avatar
360 build
Hi guys and girls,Iam new to the site,I have been given a 360 short block its been bored out 030 and o-ringed.The car it came out of ran high 12s on the odd shot of NOS,she also had cast iron heads which are long gone.The oil pan has also been deepened by the looks.The cam and lifters are still in the block also.The pistons are 030 TRW L2405 the only info I can find about them is they are forged low compression for forced induction which it never had or is it going to have.Iam wanting to give her a new lease of life and put it in my A body.Does anyone have any Ideas on these pistons and if Iam wasting my time with these low compression pistons in trying to turn this 360 into a Tyre fryer?
Any opinions or help would be much appreciated.
Thanks
I havent figured out how to post pics yet.
Old Jan 23, 2017 | 07:49 PM
What you have is a basic 365C.I. (That is a 0.030 overbored 360) with a 9.5.1 Compression ratio, With the rite head... Not much to write home about....
So if the block, crank, and Rods all checks out to be in good shape... You can move on from there.
Welcome to the site
Old Jan 23, 2017 | 08:15 PM
With the right heads you can bump the compression up a point. O ringed heads not sure on that may require iron heads.
Check with engine builder
Old Jan 23, 2017 | 08:42 PM
devo's Avatar
Racerhog,all I have found on these pistons is low compression statements as fallows 070 dish,63cc heads= 8.28 to 1 comp being the highest down to 68cc heads=7.92 to 1.The engine builder told me to aim for 9.5 comp as our fuel is real **** its 96 octane.Iam real confused by youre statement with these being 9.5 comp thats a huge difference in what I have found about them.Can someone tell me how to post pics please?
Old Jan 23, 2017 | 08:44 PM
devo's Avatar
Also I have talked with Dave Hughes and emailed him through some pics his response was even worse news on the compression ratio than what I found on the net .
cheers
Old Jan 27, 2017 | 11:57 PM
devo's Avatar
Ok so done some measurements best I could and the deck height appears to be 0.63 round the mark.The O-ring stands 0.14 up from the block.
Old Jan 29, 2017 | 11:46 AM
Last build I seen with those pistons.. Someone decked the block and milled the heads, just to get the compression up, and it still did not perform all that well.
Thats all I was pointing out. You can achive 9.0.1 - 9.5.1 if needed. But it requires some cutting....
I feel its better to change Pistons if your not going to boost the engine to use the lower compression pistons..
Just my 2 cents
Old Jan 29, 2017 | 01:52 PM
devo's Avatar
Thanks for the replys,its all great stuff to hear others input,Its just what Iam after so please keep them comming.Speaking of boost have many people on the forum had that experience of boosting turbo their small block?Its getting quiet common in Australia most likely due to the fact turbos are everywhere.
Old Jan 29, 2017 | 08:13 PM
Not much on this site.. Down under has allot going on, for sure...
Old Jan 29, 2017 | 10:02 PM
devo's Avatar
Its very tempting to go boost thats for sure almost too tempting wonder what the catch is?
Old Jan 30, 2017 | 07:44 AM
You can get an inexpensive tubo, I think the Fast FI has timing control for the boost level some fab work and a laptop with a tune in it an your golden.
Old Jan 30, 2017 | 08:52 AM
devo's Avatar
Id most likely go the blow through carb route.
Old Jan 30, 2017 | 09:28 AM
Should still have a MSD box you can control the spark curve with a laptop.
Old Jan 30, 2017 | 10:51 AM
A good short block will help, forged pistons etc. and the correct cam, the heads are less important than on an NA motor.
Old Jan 30, 2017 | 06:06 PM
https://www.theturboforums.com/forum...bo-Tech-Forum?
Old Jan 30, 2017 | 08:44 PM
devo's Avatar
thanks Coronet500 I have infact just found that website forum two days ago strangely enough.Thanks for all input its fantastic,yes i have the forged pistons already by the looks and the O ringed block to boot
64Imperial
Feb 19, 2016 07:39 PM
stickshifted
Nov 6, 2010 08:56 PM
85dodgeram350
Jun 23, 2010 12:01 AM
irishman
May 29, 2010 05:07 PM
ed22
Oct 3, 2009 01:33 PM
