360 magnum pistons with supercharging
Old 03-27-2015 | 04:54 AM
maca's Avatar
Hi
I am going to install a vortech onto my 360 magnum. I plan to run between 6 to 8 boost to keep it safe.
I have read when supercharging not to use very old cheap sand cast pistons. I also read the magnum pistons are a hypereutectic design and are stronger than the old pistons and some 360 magnums came out supercharged. Does this mean i can use them for supercharging or are they still classed as a cheap sand cast piston
thanks Greg
Old 03-27-2015 | 10:49 AM
DDodger's Avatar
Frankly at that boost level even old tech cast pistons should be fine. You must however pay attention to timing
Old 03-27-2015 | 08:12 PM
maca's Avatar
thanks,
I have a programmable ignition so I can play it safe with my timing until I learn more about the build
cheers
ANGRY6
08-15-2012 04:44 AM
johnboy
02-01-2012 12:20 PM
stickshifted
11-06-2010 09:56 PM
smackhonda
05-20-2010 09:08 PM
smackhonda
12-21-2008 05:46 PM
