360 small block
Old Jul 27, 2014 | 05:36 PM
dredgehammer's Avatar
360 small block
just wondering how to tell from the cam card if the cam is supposed to be installed straight up or 4 degrees advanced? i could get a degree wheel but if its just going to end up straight up then why waste time, any info would be great thanks.
Old Jul 27, 2014 | 05:52 PM
For a stock cam and drive, not necessary. With a performance cam and adjustable drive it is as you'll find even with all components installed as directed it will likely be off from desired position.
Old Jul 27, 2014 | 07:39 PM
moe7404's Avatar
had a 1982 ram, HEAVY DUTY 3/4 ton. 5,200 lbs. built a 360 with a 68, 340 4 speed cam at 4 degrees advanced. it did fine. my MPG was 7-8. i do NOT recommend that cam for a daily driver. do NOT try 6 degree advance. and a mild cam should not need advanced cam. would walk all over a stock ford diesel truck.
Old Jul 28, 2014 | 08:59 AM
i have a timing chain that will allow 4 degrees advance or retard. my cam is comp ex 488-491 lift with 10.2:1 comp ratio. i dont care about driveability just want it to work to the best of its ability.
Old Jul 28, 2014 | 01:05 PM
moe7404's Avatar
just remember advancing or retarding a cam does NOT give you more or less total power. it only rocks the torque shifting low RPM power to high RPM. you do NOT get more or less total power. if i was doing a high performance cam again i would set it 4 advanced. if i was doing a mild cam i would put it heads up.
Old Jul 28, 2014 | 02:55 PM
this is in a heavy truck so maybe straight up is the way to go? i will get a wheel and check it to the card. whatever the card says would be ideal no?
Old Jul 28, 2014 | 03:02 PM
Heavy vehicle makes me think straight or advanced, but duration, manual/auto and final drive ratio come into play with adjusting power curve.
Old Jul 28, 2014 | 07:20 PM
its a 5 speed truck, gears now are 3ish id say, i plan on 4:10s. would the advanced setting be better for that?
Old Jul 28, 2014 | 07:21 PM
http://www.compcams.com/Company/CC/c...?csid=628&sb=2
this is the cam i have in the engine now
pipdog69
Mar 13, 2012 11:01 PM
74bbroadrunner
Mar 13, 2012 08:19 PM
68satellite
May 23, 2009 05:33 AM
Brent1960
May 17, 2009 04:25 PM
mahd
Apr 2, 2009 09:05 AM
