383 carb setup
ok so i got the 383 running great however the holley 2 barrel carb is about done on it i am switching the intake to a edelbrock 4 barrel intake i need help choosing a carb everything will be stock except the intake the carb and headers i need mild performance also i need to know what else to order with it cause i have kickdown and i wanna make sure i have everything hooked up right
Get something like an edelbrock 600 cc or Holly 600, maybe a 650. Make sure to get the accessory Mopar linkage lever. It bolts to the carb linkage and gives you the correct setup for the trans kickdown linkage & throttle atachment
