383 carb setup
Old Aug 9, 2012 | 11:28 AM
Ty Henry's Avatar
Arrow 383 carb setup
ok so i got the 383 running great however the holley 2 barrel carb is about done on it i am switching the intake to a edelbrock 4 barrel intake i need help choosing a carb everything will be stock except the intake the carb and headers i need mild performance also i need to know what else to order with it cause i have kickdown and i wanna make sure i have everything hooked up right
Old Aug 9, 2012 | 12:01 PM
Get something like an edelbrock 600 cc or Holly 600, maybe a 650. Make sure to get the accessory Mopar linkage lever. It bolts to the carb linkage and gives you the correct setup for the trans kickdown linkage & throttle atachment
Old Aug 9, 2012 | 02:59 PM
moparted's Avatar
air cleaner also wont fit nor the kickdown linkage
Old Aug 9, 2012 | 08:10 PM
The air cleaner won't fit but the kickdown linkage will just fine with the correct 4 barrel throttle bracket and the correct throttle pin on the carb.
unruler
Mar 26, 2009 05:30 AM
gilligan
Mar 18, 2009 04:52 AM
Crazy4Carz.Com
Feb 3, 2009 10:43 PM
GTXpress
Nov 25, 2008 10:30 PM
Whiskey
Sep 11, 2008 06:25 AM
