413 fuel pump issue
Old Mar 11, 2014 | 01:49 AM
kiwimale40's Avatar
413 fuel pump issue
I have just replaced my fuel pump on my 413 old one had a small leak the replacement was a carter but it has way to much pressure petrol comes out from everywhere on the carb even wen turned off I go to disconnect the hose from the carb its got hugh pressure on it ,floods the carb all the time the old pump run at 5 psi I put the old one back on and its fine the shop who sold it to me say its a 5 psi pump is it faulty should I demand another pump appreciate your input
Old Apr 27, 2014 | 08:38 PM
moe7404's Avatar
if i remember right the pressure is controlled by the spring inside the pump. you my have racing pump? i stopped using mech pumps a LONG time ago. course i dont engines with carbs now days. i had a carter WGD 2 bbl, that would loose fuel. and i would have to crank and crank. a carter electric pump fixed the starter wearing out. i set up a override switch to fill the carb BEFORE cranking. and a good theft stop.
Old Apr 28, 2014 | 11:43 AM
Send it back as defective !!!!! Even a racing pump shouldn't go over 7-8 PSI it is the volume !
19newport72
Mar 27, 2024 06:44 PM
fmontez1
Jan 5, 2012 04:33 PM
walbey
Sep 14, 2011 02:11 PM
Dlo3575
Jul 21, 2011 05:57 AM
fury_19
Dec 29, 2009 07:26 AM
