440 bearing question
Old Jan 13, 2012 | 03:54 PM
Joe's challenger's Avatar
Gang, I am so excited that today I finished the tear down part of my 440- I have 2 questions that I am not sure why they are this way. First the front freeze plug on both sides of my block are rubber and the others are like normal I have not seen it anywhere in what I read- does anyone know why this is??
Number 2- when taken off the main caps off the block the #3 cap bearing didn't come off like the others. Again this I haven't read about, could it be a bad bearing or something that is special for the #3.
Old Jan 13, 2012 | 04:03 PM
1st Question: those are the cheap rubber replacement ones someone installed to repair a leaking freeze plug. Get rid of it.
2nd Question: #3 main bearing is a thrust bearing. You will have to use something to knock it off or pull it off. It overlaps the sides also.
Old Jan 13, 2012 | 04:12 PM
You are the MAN!!! thank you- would you think about moving to Pittsburgh as a personal consultant- I will get rid of the rubber trash, and I assume the thrust bearing is normal to only on the # 3??? Thanks for the help, I added more to my album of the teardown. I will drop the engine off at the machine shop in the next week, then I will see which way the build will go from there. I look forward to your input on some things, thanks Joe
Old Jan 14, 2012 | 10:51 AM
moparted's Avatar
when rebuilding replace the freeze plugs
Old Jan 14, 2012 | 12:08 PM
Garys69RR's Avatar
Looks as if the #3 bearing has alot of wear, also is fully grooved. Was this a H P motor? May have a pinging problem. Calculate your compression ratio before assembly. Dont want to have more than 10.5 to 1 for the street. This may be pushin it depending on your elevation.
Old Jan 14, 2012 | 05:20 PM
Thanks Gary, is there a "simple math" to calculate compression, I would think a 9.0-9.5 for weekend driver, thoughts? Joe
Old Jan 14, 2012 | 05:53 PM
Try this one: http://www.kb-silvolite.com/calc.php?action=comp
Old Jan 14, 2012 | 07:42 PM
This is the easiest and most accurate one I have ever used.
http://www.csgnetwork.com/compcalc.html
Old Jan 15, 2012 | 05:21 AM
Thanks bremereric and 500, I will get these measurments and see what I have and will get. Joe
HonkyCat
Nov 25, 2012 05:23 AM
Lorne Neilson
Nov 4, 2012 09:54 PM
BIGJOHNSMOPARS
Dec 6, 2010 12:33 PM
Dave E
Dec 14, 2009 07:01 AM
crwchf16
Oct 7, 2009 03:29 AM
