440 cast crank replacement
hi im new to this forum so sorry if this has been ask before. I would like to know if i buy a 440 that has a cast crank can i buy a steel crank to replace it?
Yes, it's a direct swap.
Use lighter aftermarket pistons and have it balanced, all the OEM type pistons are now the low compression variety 8 to1 and are 850 grams +. Good aftermarket pistons are 600 to 700 grams and you can get the compression ratio you want. If your needing a crank and pistons I would look at a stroker kit, a 4.15 crank will get you close to 500cid. Can you say burning 🔥 rubber torque. |
Are you looking to make mega HP and need a forged crank or just because you heard they're better. A cast 440 crank can support a lot of power.
(Post 141800)
(Post 141803)
