440 cast crank replacement
Old Nov 2, 2017 | 01:18 AM
Terry Howder Jr's Avatar
hi im new to this forum so sorry if this has been ask before. I would like to know if i buy a 440 that has a cast crank can i buy a steel crank to replace it?
Old Nov 2, 2017 | 03:16 PM
Yes, it's a direct swap.
Use lighter aftermarket pistons and have it balanced, all the OEM type pistons are now the low compression variety 8 to1 and are 850 grams +.
Good aftermarket pistons are 600 to 700 grams and you can get the compression ratio you want.
If your needing a crank and pistons I would look at a stroker kit, a 4.15 crank will get you close to 500cid.
Can you say burning 🔥 rubber torque.
Old Nov 2, 2017 | 03:34 PM
Are you looking to make mega HP and need a forged crank or just because you heard they're better. A cast 440 crank can support a lot of power.
Old Nov 2, 2017 | 06:27 PM
450 or so reliable HP with a cast crank, more than that go forged.
canadianwindsor
Jul 9, 2013 06:02 PM
dpmalibu
Jan 21, 2013 11:12 AM
HonkyCat
Nov 26, 2012 07:54 AM
Minnesota Guy
Oct 21, 2010 10:41 AM
atowncris
Nov 19, 2009 12:48 PM
