440 intake question
Old Mar 29, 2013 | 08:32 PM
usedknobby's Avatar
440 intake question
building a 512 stroker motor for a 1970 roadrunner, using a edelbrock performer RPM intake manifold. My question is this intake stands a little higher than a stock intake or even a edelbrock performer intake. will I be able to find an air cleaner to fit under the air grabber hood without modifying the hood? pretty sure the stock air cleaner will no longer fit. you can see the stock cleaner to the left
Old Mar 31, 2013 | 08:48 AM
Moparbob's Avatar
Holley Carb ?
try checking out a 3" drop base style Moroso
or,
check the internet, I think there are 6 pack style drop base cleaners out there ?
heres one;
http://hybrid-fiberglass-solutions.c...aseplates.html
It is one of the reasons we typically with stay low-deck 400 Blocks using Eddy Heads below 600hp/Trq., same Rod Ratios as the 512, stronger blocks.
Old Apr 1, 2013 | 04:55 PM
usedknobby's Avatar
its a edelbrock carb as well. will check out your suggestions. thanks for your response
rcknrolfender79
Mar 11, 2013 07:52 PM
dmcauto
Jul 30, 2009 07:21 PM
aftrmath99
Apr 12, 2009 06:04 PM
crashcaptn
Feb 9, 2009 11:00 AM
bighoss1999
Apr 21, 2008 02:11 PM
