440 six pack fuel line troubles
Old Apr 4, 2014 | 02:16 PM
70plumchallenger's Avatar
I just finished my build and after starting it I've got a fuel leak on the front carbuerators t brass fitting. Ive tried tape and I've tried reinstalling the fuel line. Nothing seems to work. Any help would be appreciated. Thx.
Old Apr 4, 2014 | 03:13 PM
Drag Pak's Avatar
I would look for a crack in the tube flare.
Old Apr 4, 2014 | 05:42 PM
Bad flair.... Cracked tubing seat....
Old Apr 4, 2014 | 06:00 PM
Mr.4spd's Avatar
If it's not cracked, rub some Dial bar soap on the threads and such. Reassemble and toss the Teflon tape directly in the trash. Done.
Old Apr 4, 2014 | 07:11 PM
The above is correct. The only thing "sealant" does is to lube the fitting so that it can be tightened further. The flare itself is what seals the fitting, not the threads. Examine the inside of the flare for damage both the tube and the fitting.
These should be "double" flared, by the way, to prevent the end from splitting.
Jvz
Jul 31, 2014 02:38 PM
bobclevenger
Nov 30, 2009 04:15 AM
Database13
Jul 1, 2009 08:31 PM
GTXpress
Nov 25, 2008 10:30 PM
nixtreez
Apr 4, 2008 04:28 PM
