440 thermostat
Old Oct 26, 2011 | 04:35 PM
bushwood's Avatar
440 thermostat
I have 440s on my boat and performing maintenance on the coolingsystem. I want to replace the thermostat while I have system drained and apart. However, for whatever reason I am having trouble finding a 160 degree thermostat for a big block. The thermostat that was in there was something the past mechanic put in but the engine always ran a little warmer than the other engine.
Any recommendations on where to go? I'm afraid if I go to my local parts shop, I will get a less knowledgeable person and be back at square one.
Part number ?
Thanks!
Old Oct 26, 2011 | 04:48 PM
John Van's Avatar
As long as it's the same as for a car,here's one from autozone:http://www.autozone.com/autozone/par...9_0_1640_93208
Old Oct 26, 2011 | 04:50 PM
Personnally I would run a 180 degree one in your boat...your engine performance will be better.
Old Oct 26, 2011 | 05:40 PM
John Van's Avatar
Funny you mention that! I couldn't decide between a 160 or 180 for my cuda,so I split the difference and found a 170! And the car last weekend ran it's fastest time ever @ 11.84 @ 111.65.......just saying....
john
Old Oct 26, 2011 | 07:00 PM
blue 68 gts's Avatar
Get a 180 and drill 2 small holes in it.
Old Oct 26, 2011 | 07:26 PM
bushwood's Avatar
Why the 180? At cruise, my temp is 175ish with a 160 thermostat and if I kick it up, the temps increase somewhat. Will a 180 make me too hot with the other info? Thanks
Old Oct 26, 2011 | 07:53 PM
John Van's Avatar
Bushwood,tell us more about the boat.Are there water pumps in the outdrives like the smaller boats? Where are the temp senders on the engines? Any pics?
john
Old Oct 27, 2011 | 07:32 AM
bushwood's Avatar
Salt water is pumped in via a pump mounted on the engine. That water then circulates around the antifreeze in a heat exchanger, pulling the heat away and is then discharged overboard. That is what's called a fresh water cooled system. Yes, temp senders are on the engines. I'm only pulling the thermostat because like I said, I would like to start with fresh components while I have the system broken apart.
Thanks
Old Oct 27, 2011 | 07:53 AM
John Van's Avatar
Salt water is nasty stuff. Do you ever flush out the heat exchanger with cleaner or water? I bet that boat sounds awesome under wide open throttle!
good luck,john
Old Oct 27, 2011 | 08:07 AM
If you like 160 degrees then get this high flow one for $13.95, they also come in 180 degrees.
http://www.summitracing.com/parts/MIL-16405/?rtype=10
Old Oct 27, 2011 | 02:26 PM
bushwood's Avatar
Thanks for the replys. I am getting one from Summit. For whatever reason, I drew a blank on Summit. I'm hoping the wrong thermostat was in there due to the little extra effort it took me to find a BB thermostat. I bet there was a small block one in there, causing it to run a little warmer than my manuals say it should. My engines should be consistently at 170 (in theory) whether I kick it up or not.
Thanks again.
Old Oct 27, 2011 | 03:16 PM
Thanks again.
If you check the application data a small and big block motor is the same size.
bushwood
Oct 26, 2011 03:46 PM
77Aspen
Jul 27, 2011 01:35 PM
will d
May 9, 2010 09:41 PM
67 GTX
Feb 20, 2009 06:54 AM
68 Sat
Oct 27, 2008 12:31 PM
