452s or rework the 906 heads? I need an opinion(s)
Old Apr 10, 2012 | 02:37 PM
Silverick's Avatar
Abigail, my '68 Fury 383 just turned 00,000.00 for the first time and runs borderline perfect! I'm the second owner and the car only traveled about 1,000 miles in the ten years before I got it.
The original 383 has never been apart for anything (I have every service receipt since June '68), doesn't leak although, she used to smoke a little while using compression coming down a hill and I have only had to add 1 quart of oil in the 5,000 miles that I have driven her. I was told that the umbrella seals for the valves were probably going bad and I should just drive it and it may get better. It did get better although, not perfect and she'll smoke a bit at start up but, not always.
The other issue is that my 906 heads wouldn't have 'hardened valve seats'.
I was searching Craigslist parts today, and there are a set of 452 heads complete with valves, springs rocker assy. etc. $150.
My question:
Would it be more cost effective to buy the 452 heads with the hardened valve seats and have them re-worked and install them on Abigail?
Or: Have my 906s fixed? Is it a big deal to install 'hardened valve seats'?
When the time comes, I'm going to change the timing chain and nylon sprocket to a steel unit I also have a '68 factory 4bbl intake, AVS carb and a set of C-body HP exhaust manifolds to also install.
I will save all of the original stuff.....
It's my understanding that the 452s flow almost as well as the 906s and Abigail is a cruiser! lol
Old Apr 10, 2012 | 05:23 PM
PK1's Avatar
PK1
Abigail sounds like cool ride!
NOT a big deal to install hardened seat. Most shops can do them. Valve will need to be resurfaced for the new seat. Seals are really easy to do.
Personally I would keep her OE parts. A good shop will check guide play (wear), seat condition and vac test the seal.
If seals and or guides are worn you often here small exhaust burps of air at the tailpipe.
Compression test can give clues to. If low on comp run the test wet and seal the rings. If still low the valves aren't sealing.
Old Apr 10, 2012 | 09:19 PM
Silverick's Avatar
Thanks! Abigail is a cool ride.... for a 4 door! lol
I also posted this in a C-body forum and the consensus is to keep her original parts and deep down, I knew this!!
I'll have the 906 heads done up and Abigail should be happy!
Thanks for your input!
Rick
mrzods13
May 21, 2014 03:07 PM
mrzods13
May 20, 2014 06:45 PM
mrzods13
Apr 30, 2014 06:37 AM
69POLARA383
Jul 16, 2012 10:39 AM
Brian Parmeter
Feb 25, 2010 11:18 AM
