5.9 magnum head crack between valves
Old May 15, 2012 | 11:30 AM
ghairr's Avatar
can this be fixed i have a 2000 engine with air gap 670 avenger carb is it to big engine is stock are the heads cast 302 dif from308
Old May 15, 2012 | 11:36 AM
PK1's Avatar
PK1
Heads were a defective from factory in my opinion. If you have them you can get rebuilt ones from Clear Water Cylinder Head for short money. A lot cheaper than trying to repair then. I doubt they are only cracked in one spot.
302 wont fit with magnum valve train.
The carb should be fine. Will need to be tuned to your application.
Old May 15, 2012 | 01:03 PM
302's are 318 intake runner size and 308's are 360 intake runner size.
Old May 16, 2012 | 10:10 AM
The last 3 magnums I took apart, Jeep, Dodge truck and from some car all had the valves pounded in. Not a thing was salvageable with the head. The one block we're using with LA heads and external shaft oiling we made up.
Old May 17, 2012 | 02:32 PM
CJD AUTOMOTIVE's Avatar
Engine Quest makes a really good affordable Magnum head replacement.
http://www.aamidwest.com/enginequest...r-magnum-head/
Check Ebay for the cheap cheap deal.
Laura Cullen Reynolds
Apr 22, 2024 03:24 AM
cudaracer
Jan 7, 2020 12:50 PM
RXDawg
Feb 15, 2009 08:02 PM
deadkelly
Dec 30, 2008 05:58 AM
pinky
Mar 31, 2008 07:30 PM
