'71 B300 w/318 keeps stalling
Hello,
New to the forum, forgive me if this is a common question. I recently purchased a '71 B300 with a 318. I was able to drive the van home(less than a mile). Now, when I put it in gear, the van stalls. I can turn the engine over go about 5 feet and it stalls again. I had the trans flushed, changed the oil/air filters and the van idled for a good 20 mins after the service. Seemed good to go. I drove it around the block, then the issue happen again. Any ideas? Also. I'm fairly green at any DIY jobs, but I would at least like to have an idea of what's wrong. Thanks for help! |
I would check for vacuum leaks first, Check fuel pressure/ change fuel filter. Idle too slow ? Trans flush is ok but only does 1/2 the job
Welcome.
Do you know how long it sat before you drove it? I ask because this sounds like old car contaminated or clogged fuel system. |
when it stalls, does it peter out slowly or more like wham, it's off? could be electrical if you are running a mopar box.
